Need help repairing doorframe
Old 07-25-16, 10:04 AM
O
I need some help. My contractor didn't complete our project to flatten the arches in our doorways. The top portion of the door frame open and incomplete. See attached picture.
Can I get some advice in how to handle finishing this project as I'm now stuck doing this myself?
Old 07-25-16, 10:13 AM
Received 383 Votes on 339 Posts
Welcome to the forums!
It looks like you just need to install a few small pieces of drywall, add corner bead on the outside corner then mud/tape as you normally would any drywall repair
Old 07-25-16, 10:36 AM
O
Thanks. I assume it shouldn't take very long, correct?
Old 07-25-16, 11:59 AM
It's not a big job although you do have drying time between coats of mud. You could use a setting compound to speed up the process but it takes a little more skill with the application since it doesn't sand as easy as regular joint compound.
Old 07-25-16, 05:26 PM
T
Received 15 Votes on 13 Posts
Can you show us some clearly focused pictures of the two sides. It looks like plaster. It can be fixed with drywall but it looks like you need todo some preparation first.
