Replacing a wide section of drywall
Old 08-08-16, 12:09 AM
V
OK the question is simply if the width of the drywall (wall) to be cut out and replaced is nearly is slightly less than the distance between the studs then is it essential to screw in the replacement piece to the studs or can you use some sort of piece of wood to support the patched or new piece ? The reason that I am asking is because the stud is only 1.5" wide and if the cut is not perfect (vertically) then how will the new section of drywall stay in place. Also the section of the drywall to be cut out its width is less than the distance between the two vertical wall studs.
Also is it essential to use tape for the seams or can you just use joint compound without the need or use for tape ?
Thanks
Old 08-08-16, 04:08 AM
chandler's Avatar
Received 6 Votes on 6 Posts
If you want to ensure a good place to screw the new drywall, cut it the exact inside measurements of the studs (14 1/2"). Then place two 2x4 nailers in each side of the cut out and fasten them to the existing studs. You now have sufficient nailing space on the new drywall without having to worry about missing the stud or making an errant cut.
Old 08-08-16, 04:12 AM
Received 330 Votes on 293 Posts
Ya, it's a lot easier to add framing than try to cut the drywall away from half of a stud. It's also easier to cut the drywall in a straight line when using the edge of the stud as a guide.
You always tape drywall joints! Just using j/c [no tape] will result in the joint cracking.
Old 08-08-16, 08:25 AM
Received 94 Votes on 83 Posts
Use paper tape, not the mesh stuff.
Old 08-09-16, 03:07 AM
V
@thanks everyone. I understood that tape is essential but one question how should the layering be done so that the taped seam does not seem like an elevated vertical bump or vertical hill after the three coats of joint compound has been applied ?
Old 08-09-16, 04:00 AM
chandler's Avatar
You float thinned mud around the area with a wide knife until it blends. You'll do that on your other 3 threads concerning sheetrock repair as well.
Old 08-09-16, 04:03 AM
Each coat of mud will be wider than the previous which will minimize any hump.
Old 08-09-16, 09:34 PM
V
Thank you very much everyone.
