Which primer should I use?
Old 10-25-16, 07:42 AM
I've just finished patching a sheetrock wall. Pretty good job if I do say so myself!
My question is about priming the repair- I have Ben Moore fresh start water base and oil base, and Kilz water base primers. I plan to top coat with latex semi-gloss.
Which primer would be best? Thanks, Steve
Old 10-25-16, 08:09 AM
Ben Moore latex. No need for oil based and Kilz latex is garbage.
Old 10-25-16, 08:54 AM
Semi-gloss doesn't touch up all that good, do you plan to repaint the entire wall?
Old 10-25-16, 10:05 AM
Yes, I do plan to repaint entire wall. Thanks, Steve
Old 10-25-16, 02:00 PM
primer
Update: Just finished priming the repaired section w/Ben Moore water based primer, and it looks great. Thanks for the great advice (as usual!) Steve
Old 10-25-16, 02:03 PM
Glad to hear it. Thanks for the update.
Old 10-25-16, 02:22 PM
I'd go ahead and touch up the primed repair with your semi-gloss, let it dry and then repaint the wall. Less chance of the paint flashing where the old meets the new.
Old 10-26-16, 03:20 AM
Thanks for the tip, marksr. Learn something new every day Steve
