Drywall Repair in Bathroom
stephjamm's Avatar
03-04-17, 05:53 PM   #1
We just bought a house and while removing the wall paper from the bathroom walls it looks like some of the drywall came with it. I don't know if this was already a problem or not and that is why the paper was there. I don't know what products I should use to fix it. This isn't the only spot but it is the worst. Also it appears that the ceiling is also is pealing off. Thanks you any advise is very much appreciated. Attachment 77873Attachment 77872
chandler's Avatar
GA
03-05-17, 03:19 AM   #2
Welcome to the forums! Try this method for picture attachment. The format seemed to be modified. http://www.doityourself.com/forum/el...your-post.html
marksr's Avatar
TN
03-05-17, 03:26 AM   #3
Pics might alter the advice some but basically you'd coat all the exposed gypsum with either an oil base primer or Zinnser's Gardz and then repair the wall with joint compound.
Is the ceiling paint peeling or the j/c or plaster also. Is it limited to the edge next to the wall? How old is the house?
retired painter/contractor avid DIYer
czizzi's Avatar
VA
03-05-17, 06:19 AM   #4
Agree with Mark on Gardz applied to all the exposed drywall paper. Let sit overnight and then skim coat with joint compound.
stephjamm's Avatar
03-05-17, 06:34 AM   #5
Images
I hope the pics upload this time. [ATTACH=CONFIG]77900[/ATTACH] Thanks for the replies.
marksr's Avatar
TN
03-05-17, 06:36 AM   #6
Advice stands although you'd want to at least tape off the chair rail, better yet remove it until the priming and skim coating is done.
czizzi's Avatar
VA
03-05-17, 07:29 AM   #7
I've taken liberty to upload your picture to the forum.
Is that plaster instead of drywall?
