Stick drywall in here or not?
Are there ever turns in the wall that are so small that you just apply joint compound over the wood instead of cutting a narrow strip of drywall? Or would it crack and chip when applied directly against the wood? This picture is the inside of a closet. I was planning on applying drywall everywhere except the 2" strip which faces inside of the closet. Obviously I will be applying drywall corner strips.
Is there some type of trim that will be going around the opening like a window, or is this opening between rooms. Either way a 2" piece is acceptable, how it's finished will depend on what the opening is.
UPDATE: Got that corner done with drywall. A new problem has arose. Long story short is that I need to add about 3/16th of an inch of space at the top of a closet entry way in order to fit some sliding closet doors. I already tried 1/4" drywall at the top. Not enough space. So I was thinking I'd slap some seam tape up against the wood up there, then screw on the corners, the apply joint compound. Lastly I will be screwing on a long rail for the sliding doors. Joint tape ought to suffice right?
