Remove Corner Bead?
Old 07-17-17, 12:54 PM
Received 23 Upvotes on 18 Posts
Remove Corner Bead?
I'm having a window removed and framed in and need to install sheetrock over the old opening. There is corner bead around the perimeter of the opening. Is it best to remove the bead or mud over top? I'm thinking removing it would be best to ensure the flattest possible transition between existing drywall and new.
Old 07-17-17, 01:00 PM
XSleeper's Avatar
Received 1,700 Upvotes on 1,524 Posts
Yes, remove the corner bead.
Old 07-17-17, 01:05 PM
That's what I thought. Thanks
Old 07-17-17, 02:27 PM
Received 740 Upvotes on 646 Posts
You're apt to have a hump if you don't remove the corner bead.
