Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Patching and Plastering
Reload this Page >
Patching effloresced brick/plaster(?) wall
Old 07-26-17, 07:52 PM
B
I'm dealing with some efflorescence ruining an interior wall of my condo. The condo association has corrected (we think) the exterior water intrusion issue, so now I'm looking to repair the interior wall.
The condos were built in an old, repurposed mill with solid brick walls. The interior wall has a cementious layer over the brick that is all but powder at this point in many areas. I was planning on cutting/scraping/wire-brushing all areas that seem crumbled or weakened and then re-plastering (or whatever it is that's on the walls).
Anything special that I need to do or look for? What cementious material would be good for patching these areas, as it's quite a large area?
Old 07-27-17, 03:42 AM
Received 786 Upvotes on 689 Posts
As a painter I don't recall ever having to patch damage from efflorescence but when painting over it on the interior all I've done is wire brush off what I could and then paint. Once you get it cleaned up, if the remaining plaster or cement is dusty you'd want to apply a bonding agent first.
