NJ
11-20-17, 07:57 AM
one more drywall question
drywall up and taped- 3 coats of mud and sanded (as best I can for a beginner) Looks pretty good but some small areas I can't hide every little area where it's not perfect. What is the best thing to put on the drywall/mud as a primer? Is there a recommended project that is better at hiding some flaws before paint?
WI
11-20-17, 08:14 AM
Have to fix this first, paint often makes imperfections MORE obvious rather than hide them.
NE
11-20-17, 08:16 AM
Paint does not "hide flaws". Primer will make your flaws more obvious, so if you are hot to prime that's fine but expect to go back and fix all the areas that you can see through the primer. Use a bright light to help. Even a newbie can usually do a good job taping, it just takes more skim coats to get there.
NJ
11-20-17, 08:34 AM
thanks- no i realize some will bleed thru..... I still have some skimming to do- I just wasn't sure if there was any product to put directly on the drywall before paint- or should I just paint it?
WI
11-20-17, 08:59 AM
Yes, you should use a latex primer before painting.
Anything from Zinsser would be fine.
TN
11-20-17, 09:30 AM
Inspect the wall as you apply the primer. While the primer is wet it will highlight any defects in the finish, they are a little harder to spot once the primer is dry. A bright light along with viewing the wall from an angle is also effective. Flat paints won't highlight the defects as much as a paint with a sheen but it's always best to get the drywall finish as good as you can.
retired painter/contractor
