Plaster/Drywall under interior window sill cracking
Received 0 Votes
Gents/Ladies, looking for some help with this one. We turned out heat on about 2 weeks ago when I got cold here in the northeast. We have old steam radiators on first floor of house. I’ve noticed an expanding cracking in the drywall under the window sill in the last few weeks as well. Not sure if the two are related (is it possible the steam is causing this cracking)? I’ve also noticed the decorative sill is coming off the wall now. Any thoughts on what’s causing this? Can it be remedied? If so, how?
Thanks!
Thanks!
Hard to say with no photo but my guess is that your decorative sill is plastic, and is glued down... then when it gets hot and expands it probably is probably trying to crown upward and is taking a chunk of drywall with it.
you can fix it but it will probably come back. When the crack is at its widest, fill it with setting compound like Durabond 5 easy sand.
Here are instructions for posting pics - https://www.doityourself.com/forum/e...-pictures.html I don't know if you can post from a phone or not, I'm technology challenged and don't know much about that stuff
