Repairing drywall from mirror removal
Old 07-12-20, 06:34 PM
Received 1 Vote on 1 Post
Removed a mirror in a bathroom and need to get the wall smooth again for new smaller mirror. Attempting to use Alex Plus compound in layers but welcome suggestions on product and process for best results.
Old 07-12-20, 07:23 PM
XSleeper's Avatar
Received 582 Votes on 535 Posts
First, throw that spackle in the garbage. That product is for small, shallow repairs. I'd suggest you get a small bag of setting compound. https://www.homedepot.com/p/USG-Shee...4024/205856720
Mix it up in a mud pan and fill your deep holes with that. It will set up quickly so work fast. You can give it another coat within an hour or so. Then use regular joint compound to skim over the top. You will need a sanding block to sand it d oi wn once its dry.
Old 07-13-20, 01:24 AM
Thanks. That helps. Will give it a go.
Old 07-13-20, 02:05 AM
Received 270 Votes on 239 Posts
Also if there are any ragged edges of drywall paper sticking out you should cut them off.
Old 07-13-20, 02:28 AM
Yes that I did and used Gardz sealer over it
marksr voted this post useful.
Old 07-20-20, 01:38 PM
I did the setting compound in the large hole, then multiple passes of joint compound and sanding. It all looked pretty smooth but after applying my first coat of paint with primer today it seems like it still needs some work
What should I do next? Skim coat that area? The entire wall?
Old 07-20-20, 01:45 PM
XSleeper's Avatar
A skim coat with joint compound and a wider knife and more sanding. Use a block sanding sponge.
Old 07-20-20, 01:49 PM
Thanks XSleeper. Skim the entire wall or just over the larger areas? Also what size knife would be good?
Already have and been using sanding blocks as opposed to sand paper.
Old 07-20-20, 01:58 PM
XSleeper's Avatar
Judging by the original size of the holes, skim it with a 10" knife, A skim coat is a very thin, wiped down tight on the edges coat, and you only need to do the spots that arent smooth.
If you dont like the way the repaired areas are perfectly smooth, and the rest of the wall has some texture, then yes, you would need to skim coat the whole wall. Texture doesnt show up too well in photos, so it's hard to say.
