I was going through my add on room pre filling all the butt joints with hot mud. I came across a piece of drywall above a door way where one butt joint rested on a stud and another one didn't. I had no idea way this guy would have placed a butt joint without a stud behind it. The drywall header piece is 12" wide with only a screw on the top and bottom, could it be he did that because of the short distance? Should I hot mud that joint in hopes that it doesn't crack down the road or should I cut back both sides of the butt joint to a stud and put a little replacement piece in? In the pictures below the right side butt joint is screwed to a stud and the left side is in between 2 studs Butt joint with no stud
studs.
That's a tough call. For a short distance above a door I'd be tempted to tape and mud over the joint. To do it right though I'd cut it open and either scab on a board so there is more nailing surface or cut the sheetrock so the seams are backed by the joist for support.
I found the 2x4's behind the drywall, their about 4-5 inches on each side of the butt seam. If I was to screw the drywall down on the 2 studs on each side to stiffen the butt seam, then pre fill with hot mud to strengthen the joint, you think it'll be alright after the wall crew tapes and muds it? The arrows point to my 2 pencil lines where the 2x4's are at...
Before I could push on that butt joint and it would move, I put screws in the 2x4's that were on each side of the joint and now that seam is nice and solid, doesn't move at all. Thanks for all the help....
Hello! Recently had to install a new electrical panel. The previous one was too small and new drywall was installed around it. The newer panel was larger, so they had to cut out drywall for the install.
What would you recommend on finishing/patching options for the inside of the drywall? For the outside, I'm thinking of just doing some molding for a clean finish. I would really rather not deal or mess with drywall, compound, sanding, taping, etc. Thanks!
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x935/20210215_153408_e9e89b27d4641dee2aa14b2a60e534ef0bc2215f.jpg[/img]
[i]Before[/i]
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x935/20210219_125902_5060b6baecbbdf5b57c3c474fbaa73d535e36baf.jpg[/img]
[i]After[/i]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x935/20210219_125906_76f600b95b4e9ac52f885133f23f80932d6ab845.jpg[/img]
[i]After (2)[/i]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x935/20210219_125910_7f5ceb4bc2c38ec9227d884a79ec3c3e6255a7a8.jpg[/img]
[i]After (3)[/i]
The compromised area (ceramic tile had been on the wall) in the picture runs the span off the kitchen wall (15') & measures approximately 13.5" high. I've read about the skim coating process, but was wondering, what the most efficient way to restore this relatively small area of drywall is.
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/compromised_wallboard_2f22fbb562a09eb681272ce46c173f9113bc350b.jpg[/img]
