Walkout basement leak
Old 06-29-01, 05:34 AM
This past winter, I had a problem with melting snow and also rain water seeping between the concrete slab and wood threshold of the door to my walkout basement. It completely soaked my brand new wall to wall carpet. I do plan to regrade outside the door and probably install a french drain to take water away. I'd like to know the best way to seal the crack between the slab and threshold. My guess is that it was installed incorrectly, without a waterstop, when the house was built in 1965. But maybe they didn't do that back then. On inspection the gap is quite big and irregular. Is caulking good enough? If so what kind? Butyl rubber? Is there a way to install a water stop without major rebuilding of door frame? (Ditto for the full length fixed glass window next to it.)
Old 07-11-01, 02:48 PM
demerick
NO ADVERTISING IN FORUMS
XXXXMESSAGE DELETEDXXXX
Forum topics are not to be used as public bulletin board for free posting of ads, solicitations or advertisements of any kind. When forum posts repeatedly promote a product without discussion and advice to a DIYer, it is also considered advertising.
Forum intent is an exchange of helpful problem solving methods and solutions to questions and not public advertisement.
Inappropriate postings not relevent to the intent of the web site or any postings deemed as such by the host, administrator or moderators will be edited and/or deleted.
Policy applies to ALL forums on the web site. No exceptions.
Direct your advertisements to advertisement department. Use "receive advertising info" link provided below.
If you object to policy, contact the Administrator and state your objection.
The "Contact Us" link is provided below.
Failure to comply will result in your being banned from the website.
Web Site Host & Moderator
twelvepole
