Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Patching and Plastering
Reload this Page >
How would you patch stucco around doorbell area?
Old 05-14-24, 07:42 AM
C
After removing an old horizontal doorbell, which was about 1/4 deep in stucco, I found the new doorbell camera that is going to be hardwired in is not wide enough to cover the existing hole.
How would you patch stucco around this doorbell area?
Old 05-14-24, 08:45 AM
Received 863 Upvotes on 755 Posts
You could mix up a small amount of mortar and patch it .... or even use caulking no bigger than it is.
Old 05-14-24, 01:09 PM
Received 4,059 Upvotes on 3,642 Posts
You could use a small piece of fancy wood as a filler.
It would mount over the hole and the camera would mount to it.
Old 05-15-24, 06:20 AM
C
Thanks!
What are your thoughts on something like this wall plate?
Old 05-15-24, 01:13 PM
That's one way of doing it.
That plate will mount over the stucco and the camera mounts to it.
Is that plate wider than the hole in the stucco ?
Old 05-18-24, 04:21 AM
C
Yes, that plate is wider than the hole in the stucco.
