Patching linoleum???
Old 01-12-02, 01:17 PM
Guest
Is there any way to do this? Something fell and put a nail head (large one) size hole in the floor. I can glue down the edges, but the top shiney part is missing. I'm afraid to mop because I don't want it to soak up water and mildew under the whole floor. Is there anything I can do?
Old 01-17-02, 09:59 AM
The Soulgirl
You can fashion a repair from a left over piece or if you dont have that then take a small section from under a permanent piece of furniture. If its in the kitchen the flooring contractor should have extended the lino under the kitchen units for example. using a template cut a piece from the spare bit and make the damaged area the same size too. Pop into place and seal with a clear silicone.
