i once got a hole in a door and i found a piece of thin plywood
cut it bigger than the hole and put in place over the hole and put
some molding around it, and it looked like it was made that way.
just an idea i had Cork
What is the best way to repair or rebuild a small corner section of dry wall, that will be hidden, because the area that needs to be repaired will be behind a forced air heating vent. It needs to be repaired because the part of the wall that is missing is where the vent cover screws into the wall.Read More
I just finished sanding the drywall repairs to my kitchen. Does anyone know the quickest way to clean up the dust from the walls and ceilings so I can paint? It seems the more I wipe them with a dry cloth, the more they need wiping? How much is enough wiping?
Thanks!Read More
