hole in metal door
Debbie Brittain's Avatar
02-25-02, 06:29 AM   #1
Debbie Brittain
hole in metal door
does any one know how to fix a hole in a metal door? thanks
the_tow_guy's Avatar
FL
02-26-02, 05:42 AM   #2
Size and shape of hole? Liquid steel (comes in a tube) or an epoxy patcher should work unless it's a big hole.
02-26-02, 06:15 AM   #3
Debbie Brittain
hole in metal door
The hole was made by a screw about 1/4 inch. Do I need to put anything in the hole first? Thanks for your help
FL
02-27-02, 04:43 AM   #4
That size hole probably not, but you might want to use just a little filler at a time and not try to fill the entire hole all at once. Build it up a little at a time until it's a little above the surface, then sand flush and paint.
Repairman22's Avatar
02-27-02, 09:00 PM   #5
Use "Bondo" same stuff to fix auto body. Easy to sand when dry.
