repair rust spot on bathtub
Old 09-03-01, 06:33 PM
beebow's Avatar
Smile
I have a 3 by 12 feet planting area with an east exposure in Phoenix, Arizona and I would like suggestions on planting a flower bed that gets full sun exposure 1/2 of the day. Most of the plants I've tried in the past have died from the heat. The only thing I can find that will live is vinca and it gets pretty boring. Any ideas?
Old 03-09-02, 03:58 PM
bearsandbugs
I have a rust spot about the size of a fifty cent piece in the corner of my ceramic tub, how do I fix it?
Old 03-10-02, 01:35 PM
the_tow_guy's Avatar
Received 262 Upvotes on 213 Posts
Try using C-L-R which you should be able to find in the cleaning products area of your grocery of home center. If it is really stubborn, try a pumice stick. These are usually either with cleaning products or in the plumbing area. They are made of volcanic pumice and all you do is wet the end of the stick and rub the stain. Will remove practically anything and not scratch the porcelain.
