Cat's fur matted, loose…what to do?
My four year old cat's fur (medium length) can be found anywhere she sleeps in fairly large amounts. She also is getting matted on her back. Does she need special vitamins, or what can I do for her?
Cyn
Cyn
It is time for shedding, but...
Mattison is right, if this is something new, you may want to check with your vet. SOON. Sometimes major hairloss can be signs of serious illnesses.
If it is simply shedding, which as I mentioned it is still that time of year, it is not a worry.
To remove mats from critters, I have a very good tip. Use a seam ripper, to cut the fur out along the skinline. You have to be very careful, as the pointed ends can poke, but if you can pull the mat up enough, you can slide the seam ripper along the mat, above the skin, and slice it out quickly.
Buy a Brand New seam ripper for this, so it is very sharp, and be sure to buy a new one every so often. I learned this little trick when I was working as a vet tech and doing animal rescue years ago.
Hope this helps, keep us posted!
RhainyC
RhainyC
