How can I build a kitty condo?
Old 02-16-01, 08:53 AM
Guest
Question
I am trying to put together the right materials for building a kitty condo. I have industrial carpet staples, a pneumatic stapler/nailer, good carpet, sisal rope, wood posts and a 3/4" piece of plywood for the base. What is the material they normally use for those tubes? Is it pressed paperboard or something? Where can I find it? It's pretty thick stuff - about 1/2 inch. Is it normally hard to find or am I looking in all of the wrong places?
Old 02-16-01, 09:07 AM
Guest
It's probably cardboard tubing (just really large).
I imagine it's hard to come by if you aren't associated with some kind of industry that just happens to use the rolls for something.
BUT, I thought of this - you could get a 5-gallon bucket (new or from the bakery or meat dept at the grocery store), cut the bottom out, and cover that with carpet.
Old 08-04-06, 09:51 PM
Thumbs up kitty condo
The stuff you are lookig for is sold at Home Depot it is tubing for cement just ask some one or look online for making your own condo they are a lot of help.
Old 08-08-06, 08:57 AM
B
Yeah... it is called sono tube and if you ask at any building supply place they will know what you want. It will come in sizes from 6" on up to 24". I would avoid the staples except on the bottom of your base. You can attach the carpet with liquid nails or hot glue and just use the staples to hold the carpet until the glue drys, then pull them out.
Old 03-06-08, 11:48 AM
im building a kitty condo myself and i have found that concrete forms are perfect for the tubing....you can get them at any hardware store such as menards home depot lowes etc
Old 03-06-08, 01:27 PM
dcjredline's Avatar
Or you can just use a square "tube" instead.
