DIY Lighting
DIY Lighting
I need to cut down on the start up costs of getting a WebShow going. The utility halogen bulb lighting in my budget doesn't have shades. Do you know of any DIY solutions for this?
I assume you are using a construction type lamp that is in a metal enclosure.
Halogen lighting for photography is best when it is indirect.
A studio will bounce the light off a white umbrella that is open towards the subject.
You could use some other type of white reflector but you need to be careful as halogen lamps can easily start a fire.
It will take a fair amount of wattage likely well over 1000 watts total.
Make sure the bulbs that are in the fixture are rated at 120 volts as the long life 130 volt type give off a less that white light.
If the OP would return with more information regarding their "WebShow", I could provide them with the information they are looking for.
By the sounds of it, they are looking for barn door style shutters for their pre-existing/already owned lights.
Although not my prefered way of doing things (don't like this type of lighting), there are plenty of sources for DIY designs or commercially available aftermarket kits. Knowing what the OP is working with (make/model) is a huge factor.
If I was doing a small set video, I'd personally go with a large light box arrangement. Using a large white (thin) sheet or raw cloth material, create a wall with the material between the person being filmed and the lights. The light will hit the material, softening the light and reducing the shadows drasticly. The larger the sheet (and light source) the better quality light.
I've done this for still photography with cars. I had the wife stich a few white sheets together, and we used 4 2ftx4ft (4bulb) florecent fixtures. I don't remember the bulb color temp however.
I like halogen lights, but they are a bit dodgy when it comes to safety concerns. What kind of space will you be working on? I know this is an old thread, so I hope you figured it all out and might share with us the outcome?
