ignition
Old 08-26-02, 05:27 PM
aprettykitty84
ignition
I need to know how to pull the ignition out of the column from a 1987 f 150.
Old 08-28-02, 05:31 PM
B
to remove the key and tumbler there is usually a small hole below the tumbler you push in with a small punch or object that will fit into the hole at the same time turn key and pull out you are realising the pin that holds the tumbler in when you do this,
if you are referring to the ignition switch it is mounted lower on the colomn with two bolts and can be accesed eisier by lowering the column by removing the bracket bolts and may require indicator cable to be disconnected if an automatic.
