power steering
power steering
how do you change the powe steering in a 89 chev. surburban. we are having trouble taking out the old one.
if your changing the pump you need a pully remover that can be rented at alot of auto parts stores then just remove all bolts and pressure and return lines and should come right off.
if you are changing the gear box you will need a pitman arm puller also can be rented at most parts stores.
