Universal Joint Question
Old 09-28-02, 08:59 AM
Bucsdk
Question 87 Chevy R10 1/2 ton - Universal Joint
Trying to replace the universal joint - where can I find a step-by-step guide without buying the manual?
Old 09-29-02, 04:31 AM
mark your drive shaft so you install the yokes the exact same way as it came apart, they make a ujoint press tool that is helpful that can be rented at some parts stores, you can also take the whole driveshaft to a driveline shop and have them replace the ujoints then all you have to do is r and r the driveshaft.
http://www.cybrrpartspro.com/Manual%20Lookup/cal_ModelLookup.html
try this link it may have a more detailed description, just copy and paste it to the address bar.
