Refrigerator Problem
Old 10-11-02, 08:59 PM
rsfw30a
The refrigerator in my RV has stopped cooling. The gas and electric functions work but does not cool. Instead of replacing it with the same unit I was wondering if I could install a compact under the counter refrigerator (110V) and operate it via an inverter while on the road and then switching to normal 110V power at a campsite. Does anyone know if this is feasible or would a refrigerator with a compressor not function while traveling.
Thanks, Ben
Old 10-12-02, 02:03 AM
im sure it would probably work they do make them that runs on 12 volt and would save you from buying an invertor, and most can also be used on 110 a/c with a step down transformer adapter.
Old 10-17-02, 04:16 PM
Pete
You're not going to beleive this but the solution may be as simple as pulling the old refrigerator out and turning it upside down. This dislodges a crystalized particle in the evaporator orifice and allows the refrigerant to circulate again. Try it. It worked for the dometic refer in my RV.
~pete~
