134A conversion
Old 10-21-02, 09:13 PM
D
134A conversion
I have a 1986 Dodge Ramcharger 318 truck and the air conditioner was changed to 134A and it want hold a charge. A dye test was done and it didn't show anything. What could it be?
Old 10-22-02, 03:10 PM
B
it could be anything dye sometimes does not show up unless it is a very significant leak, also may not show up if evaporator is leaking underdash.
Old 11-03-02, 10:31 AM
GregH's Avatar
Super Moderator
Received 65 Votes on 60 Posts
dnoonkeste:
It is likely that whoever converted the system did not do it correctly. A conversion of this type requires that the seals be changed and that the compressor be removed to change the oil to PAG type and replace the shaft seal. The hoses may also have to be changed depending on MFR's recommendation. If someone did all this, a leak check before installing refrigerant is standard practice.
