can't shift off Park
Old 11-21-02, 07:44 PM
weirdboy
Angry can't shift off Park
Ford 86 F150, automatic transmission. Was working fine then next day, can't get off park. someone suggested checking transmission fluid--which was very low -- didn't even show up on dip stick. Filled that, but didn't solve the problem. Hate to crank on it too hard to try and get it out of park--but that doesn't seem to work either. Do I need to let run for a while to fluid where it belongs or is there maybe a problem on the steering colum?
Old 11-22-02, 07:30 PM
B
if you cant move the shifter down to drive it is likely a problem in the column and i would suggest taking to shop to have repaired.
