suggest getting a manual for your vehicle or a subscription to alldata if you are going to attempt to replace the oilpump yourself
are you certain it needs an oilpump?
My step-father recently passed away. He had a 1971 Dodge 100 Adventurer SE Pickup Truck. It has 156,307 miles on it. It is an automatic, am radio, air: it needs freon, I believe it is a 6 cylinder; I am not sure. The truck is in fair shape. My mom is wanting to sell the truck. I am trying to find out what it might be worth. Can any one help me? I went to KBB and NADA, but could not find anything. Any ideas? ANY HELP WOULD BE APPRECIATED!!!!!!!!Read More
98 dodge 250 pickup / diesel
Short easy question that I hope you all can help with,
About 2 days ago I was driving along and went through a construction site on the road....hit a few bumps and went my way. About 5 miles later i noticed it took a little more pressure to make the truck stop.
So I'm thinking that there is an air bubble in the line (from the bouncing......front end is way heavy with the diesel) and its time to flush the lines out.
Today (friday) when I started the truck, the brake / abs light was on, this is a new one for me .
Question is....I know how to bleed brakes on veh, but this being the first truck I have owned with anti-lock, do I have to do anything "special" in order to do it correctly?
I've inspected the system for leaks / breaks and I have also checked level of fluid (good on both counts).
But crawling underneath I've noticed what seems to be a second master cylinder on the frame wich also has a bleed screw on it . Do I bleed that before the rear set?..or not at all?
If anyone can point me in the right direction it would be deeply appreciated!!!Read More
