transmission shiftpoints
Old 03-29-03, 08:34 PM
tundratrucker
vehicle--1985 3/4T GMC 4X4; TH400
PROBLEM--SHIFTPOINTS CHANGED;
QUESTION--WHAT CONDITIONS CONTRIBUTE TO THIS SYMPTOM?
SO FAR--CHANGED THE MODULATOR, PROBLEM DID NOT CHANGE
ANY IDEAS?
Old 03-29-03, 09:47 PM
WeldGod's Avatar
If its vacuum modulator on it, a vacuum leak on the other end could contribute. Or your valve bodies inside the transmission could be getting gummed up. That is about all I can think of, but transmissions are not my strong point.
Old 03-31-03, 10:08 AM
tundratrucker
re:transmission shiftpoints
thanks for the reply;
I hadn't considered the valvebody situation;
this a.m. took rig to mech. who discovered and replaced an oil
soaked vacuum line which proved to be the cause of the problem.
tnx agn,
roy
