speaker replacement
Old 04-11-03, 09:08 PM
riggs206
speaker replacement
I have a 96 Chevy Silverado extended cab. I would like to know how to replace the rear speakers. Is there a certain way that the side cover panels come off. I have only seen a couple of screws and I am sure there is something else that is holding the panels on.
All tips and suggestions would be appreciated.
Old 04-12-03, 02:43 AM
WeldGod's Avatar
This link will have all of the info you need. After you enter you year and model, click on Body and trim, then interior, the door panels.
Cut And Paste
http://www.cybrrpartspro.com/Manual%20Lookup/cal_ModelLookup.html
Old 04-12-03, 09:51 AM
riggs206
web address
You posted a web address that I could check out to see all the info that I needed. I could not get the address to work. Could you try and send me the web address again. I think one reason that it did not work is that the spelling was incorrect of the word
cyber. If you could repost that address so that I can just click on it, I would appreciate it.
Old 05-02-03, 11:54 PM
Harlon Alford
Those panels should be held in place by some "clips". Pieces of plastic extending from the panel with a metal clip on them. They lock into slots in the sheet metal inside the cab. A trim removal tool should be used to pry them loose. Just be careful not to lose the metal clips. And pry straight out on the panels. Any sideways pressure could break off the plastic.
Old 05-07-03, 06:41 AM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
Old 05-07-03, 05:17 PM
magister
Hey, that's a cool link and apparently, it relates to all kinds of procedures and vehicles; Good going, guys...
Peace Out;
R
