97 Chevy utility van 2500 problems
Old 04-29-03, 06:55 PM
ralphluv
The other day going to work i made a sharp right hand turn and all of the sudden the power steering went and lost brakes can any one help thanks
Old 04-30-03, 02:04 AM
WeldGod's Avatar
Wow, that could be a lot of things. Did you have a belt break? Your breaks might have lost vacuum. Did your breaks and steering return or did they stay out? Your master cylinder/booster are right over the steering shaft, did you look for physical damage?
Old 05-04-03, 08:05 AM
truckdrivinfool
Your van doesn't have hydroboost for the brakes does it? For the rest of you - do any manufactures still use hydroboost?
Old 05-12-03, 08:06 PM
msargent's Avatar
Yes, GM still uses hydroboost on some vans.. Sounds like you hit this one right.. Look for powersteering hose blown..1 of the high pressure hoses sounds like the culprit...
