replacing the fuel pump on a 1978 360 dodge engine
Old 05-07-03, 01:54 PM
apladay
Is there a trick to holding the fuel pump push rod up while installing a mechanical fuel pump on the 360 dodge LA blocks?
On a small block chev you were able to place a longer bolt in at the bottom of the water pump, which would hold the push rod in place.
Thank you for a reply,
Old 05-08-03, 08:34 PM
GregH's Avatar
Super Moderator
apladay:
I have coated the pushrod with white grease to hold it in place.
Old 05-10-03, 05:46 PM
WeldGod's Avatar
Sounds like a plan to me.
Old 05-12-03, 02:09 PM
apladay
Thanks for the grease tip
Upon removing the old pump, I found that the pump runs on an eccentric which is directly in front of the timing chain.
made for reinstalling an easy process.
