1985 ford 2.8 problem?
Old 05-16-03, 03:32 PM
bighenny
i have a 1985 ford bronco 2 with 2.8 engine,i use it for driving back and forth to work,its about 15 k to work. the problem is
the runs great when its cold but by the time i almost get to
work the truck loses power, then i pull off on the side of the
road and it gets the power back,it take a few minutes. the more
i drive the truck the worst it getting,can't even drive around for
5 minutes.i took it to a machanic,he couldn't find the problem.
so if anyone has any sollutions,let me hear'em
Old 05-17-03, 01:50 AM
shanehaz1
You may have a clogged catylitic converter.
Check your exhaust flow.
Hope that helps
Old 05-17-03, 02:42 PM
WeldGod's Avatar
Check your exhaust, if you exhaust is fine check your compression cold and the hot.
Old 05-22-03, 02:28 PM
CustomIron
i have an 86 BII,2.9,it did the same thing a while back,was the fuel filter located on the frame
