transmission cooler
Old 08-31-03, 03:54 PM
northwoods
transmission cooler
I have a 97 Chev Blazer that I will be using to pull a snowmobile trailer quite often this winter. I was wondering if you recommend adding a transmission cooler? If so what size and is this a fairly easy installation?
Thanks
Old 09-01-03, 07:17 AM
E
Absolutely, the cooler you keep the tranny the longer you'll get service out of it. Make sure you follow the severe service schedule for service which should suggest you change fluid and filter every year.
As for size you should get something to match the load you'll be towing, don't want to get it so the tranny doesn't get warm enough.
Again installation should be easy.
