95 F 250 quits running
95 F 250 quits running as going down the road. sometimes starts right back up as still coasting along. sometimes has to sit a minute or thirty, then will start. sometimes won`t start , then starts a little later. 4.9 litre 6 cyl. changed out ignition module and later changed coil. problem still persists. help.
you need to determine if you are losing fire or fuel first, next time it wont start see if it has spark at the plug if not check for spark at the coil, if it has spark you should be checking fuel pressure, does it have dual tanks does the problem occur on both tanks?
