88 ford 4x4 pickup wont start
Old 11-17-03, 05:55 PM
bigfoot631
88 ford f150 4x4 wont start
has spark so iknow its a fuel problem
In have changed the relay ,fuel pump ,and even the EEC IV computer. I have checked the fuse and inspected the wires.
I dont know what else to do please help.
Old 11-17-03, 11:45 PM
WeldGod's Avatar
The next step is to read or have your trouble codes read. My first guess is vacuum in the fuel manifold is not adequate or the pressure regulator is not working right. Are we sure the spark timing is OK and the air system is O.K.?
Old 11-19-03, 04:23 AM
hogfan's Avatar
Check the ground wires at the battery one of the small wires is the computer ground. If you know were the EEC proccesor is check pins 20-40-and 60 these are all of the grounds. Did you replace the EEC relay also?
