Low Beam Headlights-No Work on 95 Chevy K-1500.
Old 02-21-04, 04:22 PM
Mike Frazier
Question Low Beam Headlights-No Work on 95 Chevy K-1500.
Low beam headlights do not work on my 95 Chevy K-1500 pick-up truck. High beams work fine. All related fuses Ok. Wire brushed both grounds and looked at both bulbs (composite headlights), they were OK. Used test light on both headlamp sockets--no electricity!!! Chiltons repair manual (8055 or 28624)chasis electric schematic (Diagram 28 Page 6-42) shows a "beam select switch". Would this be the lever on the steering column ?If not, what is it and where is it located on the vehicle? I think this may be the source of my problem.
Old 02-21-04, 08:32 PM
fordman30
sounds like to me it is your dimmer switch going bad...that would be my guess
Old 02-22-04, 10:04 AM
Mike Frazier
Fordman 30. Thanks for your best guess. I think it sounds like the dimmer switch as well. Looks like the dealership will get to play with this one! Thanks again.
