Transmission Problem
Old 04-06-04, 08:35 PM
humblethee
Post long delay
My Explorer, was running perfectly ok untill a trans fluid change @ one of those you know oil change places.
Only in the morning after the truck has sit all night when I move the gear shift from park to drive there is a very long delay before the truck go into gear
Old 04-07-04, 05:10 PM
fordman30
have you double check the trans. fluid?
Old 04-08-04, 03:39 PM
D
Was the filter changed or did they use one of the fluid exchange machines,it may be worth pulling the pan and changing the filter if they used the machine.
Old 04-16-04, 02:50 PM
humblethee
Talking trans delay out of park
thank you the fluid change with filter did it
