Ford 2001 F150 discrepancy.
Old 07-05-04, 08:36 PM
sierraa
I have a 2001 Ford F150 with a 4.6 Triton automatic transmission. It starts OK, but when I got up to a range of 45 to 65 mph it starts to jerk and shake. Sometimes is hard to start, but ounce starts, runs pretty good for about 30 minutes, when starts all over again jerking close to stall. Need a clue to start looking
Old 07-07-04, 05:35 AM
B
should start by having codes read in the computer.
Old 07-16-04, 08:25 PM
sierraa
No computer indications (codes) at advisory panel.
Old 07-17-04, 04:20 AM
B
may be losing fuel pressure recomend having fuel pressure checked while the vehicle is acting up to see if it is losing pressure.
if the check engine light ever comes on it should have codes stored in the computer that requires a scanner to read, which means you can take to a shop or you could try autozone as they do have the capability of scanning obd2 vehicles.
Old 10-13-04, 09:02 AM
Thumbs up Change those socalled 100,000 mile spark plugs
I have same truck,ended up being the spark plugs at about 76,000 Km or 45,000 miles.Don't be cheap though get good plugs????
