ditributor/timming problome 89 ford bronco5.0
Old 08-16-04, 10:49 AM
seldner
i took out the distibutor to change the tci module iv gotton the bronco to fire up but im way out of timming im stuck in tdc instead of btdc. do i repeat the prosess of taking out the distributor again and doing the firing proceedure!
any help would be great.
Old 08-17-04, 03:12 AM
B
if it runs but you do not have enough room to turn the distributer enough to get it in time then you could probably just lift the distributer and move it one tooth counter clockwise this should advance it enough to be able to set the timing you may have to bump the engine over slightly to get the distributer to engage the oil pump completly.
Old 10-02-04, 12:25 AM
Knockerloose
bronco 2
i had one and it ran like crap until i changed the alternator
