2000 Toyota Tundra - Parking Lights will not go off
Old 09-28-04, 10:54 AM
Marshall Buttrey
This has started like a hair puller.
PU is a 2000 Tundra, V8, no tow package, entry cab
The only way I can get the parking lights (and instrument lights) to go off is to disconnect the battery. Problem started a few months ago, but would go off after using the remote to lock and unlock the doors several times. Now problem is solid.
Ignition key is removed.
I connect the battery, the lights stay off.
I turn on the parking lights (ONLY), and turn them off, the lights stay on.
I disconnect and re-connect the battery and the cycle repeats.
It does not seem to be a switch of relay, or they would be on when I re-connect the battery.
Any help would be appreciated. I location for a wiring diagram would be a great help. Also a diagram showing component locations.
Thanks very much.
Old 10-14-04, 08:53 PM
Have you got the problem fixed yet? If not, my guess is the relay. See if you have another relay on the vehicle which is the same, and swap them.
