installing snow plow
Old 11-16-04, 10:41 AM
jetsfan68
How difficult is it to install a new or used plow onto a truck?? I'd like to get my hands on a used one before winter-time and am wondering how much knowledge is needed to install.
Old 11-17-04, 09:32 AM
A
thay are not to hard if getting a used one try and make sure that it is from the samemodel of truck as yours because if your lucky aloot of the litel brackets needed will be there so some fabrication on your part may not need to be doe also if it is used try and see it working some of the hydrolics are very costly to repair and some are unrepairable if new than some fabricating may be needed depending on the unit lots of try and take downs untill you get it to bolt up properly also some welding is needed
good luck....
