Choking F-150
Old 12-02-04, 04:17 PM
speedo
Choking F-150
I have a 2001 4.6 F-150 that I check the oil and air filter the other day. Since then the engine has been choking and the idiot light (Check Engine) is on. When I put the truck in reverse there there is a squeaking noise from the rear end. My mech. says my bearings are not loose. But it happens only in reverse.
HELP!
Sorry I have not gotten back to ya, but I have been on jury duty. So I checked all of the hoses and they fit tight and it runs a little smother. It still shakes a little at low speeds. And the spueaking is coming from the rear of the the truck when I put it in reverse.
Old 12-02-04, 05:26 PM
wow lets start with one at a time when you checked the airfilter did you reseal the air box good and no hoses off double check an air leak in the systm will cause the choking
as th the squeel try and see if it is from the motor or the rear end the noise get back to me
Old 12-08-04, 04:48 AM
hogfan's Avatar
Choking?
This might be a vacuum leak? Check the PCV valve hose the rubber boots seem to get holes in them?
