Transmission trouble 1985 Chev 1 ton
Old 01-02-05, 11:58 AM
2bitnag
Post Transmission trouble 1985 Chev 1 ton
We have a 1985 1 ton Chevy that will not go into gear. (standard tranny 4 spd.) What is wrong and how do we fix it?
Old 01-02-05, 07:44 PM
WeldGod's Avatar
Is the clutch working or dose it just grind when you try to put it in gear?
Old 01-03-05, 05:53 PM
2bitnag
Post 1985 tranny
The clutch is brand new and it doesn't grind as it it will not even go into gear. It is like a wall.
Old 01-03-05, 06:26 PM
WeldGod's Avatar
It could be a few things. The gates on the transmission could be not allowing it in to gear. It could also be hydraulic problems, a lot of times after working on the clutch this happens. Did you have the new clutch put in? Did it quit going in to gear after that?
Old 01-04-05, 08:54 AM
2bitnag
Post 1985 tranny
The clutch was put in in June and was installed by a shop. It worked good up until now but it did "clunk" every once in awhile.
