93 GMC PU - Tailgate will not open
Old 01-04-05, 06:47 AM
j_joneser
Question 93 GMC PU - Tailgate will not open
One of the pins will not disengage from the sidewall to allow the tail gate to open. I appears that the rod/cable has broken away from the handle. Can this be repaired or does the entire tailgate need to be replaces. Also is there any trick to get the tailgate opened in this situation?
Thanks
Old 01-04-05, 05:15 PM
tinker toys
remove the handle unit and the cable or rod will be accesable to pull by hand.
1 side at a time. if it off on the latch end need to get sonthing slim at the latch end and jimy it.
All parts are replaceable by themselves. some are even at aftermarket brands..
Old 01-05-05, 06:18 AM
there may be an access cover in side the tail gate just open it and try and work the linkage if you have a bed liner you will ave to remove the tail gate pice first
