1989 chev tracker idle trouble
Old 01-10-05, 06:41 AM
the butchers wife
our 1989 Chv Tracker sounds like it's purring when it's idle. It will rev up high then cut out to the propper idle then rev up again etc. Could this be an oxygen sensor that is not working propperly? will the problem come up in code form when plugged into the computer? Thanks guys
Old 01-10-05, 09:28 AM
A
you could get it scaned to se codes but i would check if the throtal body and idel motor is dirty first clean with air intake cleaner
