Diesel problem
Old 02-01-05, 11:42 AM
SOU510A
Diesel problem
This applies to a John Deere 770; a small 3 cyl diesel utility tractor. I was running down the road, and it just quit running. It did not miss, stutter, smoke or shake before quitting. It has plenty of fuel, all the fuses look ok. The tractor has low hrs, and is in good condition. It cranks over good, but does not smoke, hit or give any indication it is trying to start. Any ideas?
Thanks
Steve
Old 02-02-05, 05:51 AM
did you have fuel conditioner in the tank too fuel could have gelled in the cold also try a new fuel filter you may have to prime system by bleeding the injectors
Old 02-11-05, 02:58 PM
jdallum
bad fuel shutoff solenoid. I ran into that problem on a small jd at work.
