94 Chevy 1500 4x4 Ignition key/cylinder stuck in on position
Old 02-10-05, 08:27 AM
G
good420
Question 94 Chevy 1500 4x4 Ignition key/cylinder stuck in on position
Cannot turn key back to off position. How do I access the key cylinder? Do I need to remove the steering wheel? When I access the cylinder, is there a mechnical release or do I need to replace the whole cylinder? Also I believe I have a faulty ignition switch, I like to know where it is located. Thanks in advance for any information.
Old 02-10-05, 10:25 AM
A
the wheel needs to be removed you have to turn the key to the run posision and there is a push pin push it in and pull the cylinder out if you need a new cylinder you should be able to get one at any parts store thay do not cost much
