91 S10 Ignition stuck "ON" position
Old 02-27-05, 01:21 PM
frmichaud
I cannot get my key out of the ON position in the ignition. I had to disconnect the battery to stop the engine. Does anyone think that my ignition key cylinder might have to be replaced? If yes, do I havre to remove the streering wheel? I was able to get my key out quite easily in the ON position.
Old 02-28-05, 05:48 AM
try and take the cover off the column and see if you ca see anything binding i could be just that too remove the cylinder yes you need to pull the wheel and turnsinnal switch some special tools are needed
Old 02-28-05, 04:28 PM
frmichaud
Thank you for the information Doctor. I'll try it and let you know what happens
