94 GM (L) side axle seal on 4 WD replacement help?
Old 03-12-05, 07:31 PM
Other than removeing the outer half shaft which I have done on the other side to replace shaft assy. what would need to be done to replace seal on inner axle to case.This is starting to leak gear oil and was wondering if the short axle has clearence to pull straight out and if anything retains axle inside housing?
Thanks to anyone with info.
Old 03-15-05, 09:30 AM
depends on which diferental housing you have some do have the clearance to come out the only way to tell you is to give it a try if not than you will need to pull the spindel apart to remove it
Old 05-08-05, 12:07 PM
rocky 9
snap ring retention. A pry bar and tapping with a hammer should be enough to pop it out.
