Behind the air cleaner box you will find two or more relays... fuel pump, EEC and possibly trailer tow... IIRC, the fuel pump relay will have a green connector.
I am thinking about buying a 29' 81 Allegro motor home. Price $5000. OBO. They tell me it has only 48,000 K original miles? It has a Dodge 440 motor,new radiator and hoses,Onan 4K generator,solar battery charger, new tires, new AC, new fridge, and many other interior improvements. The only thing I could find wrong with it was the exhaust maniflod seemed to have some leakage. Someone told me this could be very expensive to repair, does anyone know about what that would cost to fix? Would this be something I could do myself? or is this something that a Muffler repair shop should be able to handle? Thanks for any info. RH
I have a 1990 GMC Suburban 4WD 1500 with the 350 gas engine. Recently I noticed that I was getting little heat. Checked upper and lower hoses and they were hot, so I replaced the thermostadt. Better, but not by much. After running the truck for one half hour both hoses were hot, but the radiator was cold (all over). Never have run into this before and wonder if you have an idea.
Thanks
